the wash machine does not allways spin, I think the problem is only by the last spin cycle.
Please observe your machine and report back on the following.
1. Does the spin problem occur after the wash cycle and after the rinse cycle, or does it always spin after the wash cycle and occasionally have problems after the rinse cycle?
2. Does this happen on all cycles (regular, perm press etc)?
Hi, I this is what I saw, the problem is only by the last spin, sometimes it doesn't spin and when I push it it starts spinning, but the clothes stay wet.
The motor runs also the clutch is moving fine, maybe It's only a miner part that spins the basket.
Well, it sounds like a clutch problem, but I don't know why it would spin after the wash cycle.
Anyway, I suggest you replace the clutch and see if that fixes it.
