I have a Maytag washer that works only in the delicate cycle. When set to other cycles (REGULAR FABRICS, PERMANENT PRESS and QUICK CYCLE) the washer will fill with water and the timer will continue to run but the the washer will not agitate, spin or drain. Everything works OK in the "DELICATES" cycle. Thanks.
Since everything works ok in one cycle it is likely your timer is defective. You will have to replace it to know for sure. Here is the part if you decide to try it. Part number: AP4026151
Originally Posted by: rdharding ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have a Maytag washer that works only in the delicate cycle. When set to other cycles (REGULAR FABRICS, PERMANENT PRESS and QUICK CYCLE) the washer will fill with water and the timer will continue to run but the the washer will not agitate, spin or drain. Everything works OK in the "DELICATES" cycle. Thanks. I just summited an identical problem for a Maytag machine. I was wondering if you tried a time and it then worked OK?
I replaced the timer and it works great now.
