JWATSON
#1 Posted : Monday, September 28, 2009 4:37:19 PM(UTC)
JWATSON
Ge Front Load Dryer Making Grinding Noise
sidfink43
#2 Posted : Tuesday, September 29, 2009 3:46:18 PM(UTC)
sidfink43
See if you can tell if it is coming from the rear. If it is, it is likely the rear bearing assembly. Here is the replacement kit.
Part number: AP2619300
JWATSON
#3 Posted : Wednesday, September 30, 2009 3:20:19 PM(UTC)
JWATSON
Thank you so much for your reply. It is definitely coming from the rear. Thanks so much!!
