docrayuri
#1 Posted : Tuesday, September 29, 2009 2:53:51 AM(UTC)
docrayuri
I want to switch the side the hinges are located on, the door is stainless steel it doesn't appear to have any predrilled holes drilled on the door to accept the hinges, the box has the holes drilled but not the door
#2 Posted : Tuesday, September 29, 2009 4:35:14 AM(UTC)
I looked up the unit on the Kenmore parts site and it clearly shows that the door has the holes with plugs in them.
Here is the link though I am not sure that the filter on this site will let you go to it
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=25374813400+
Perhaps yours is an early revision of this Model and reversing the doors is not possible.
