I get F1 code and alarm on my oven. I can turn the the code off momentarally and the oven works fine. I want to know if there is a way to turn the code off? All people I talk to tell me I can't get the control panel or touch pad that they are no longer made. Can anyone help?
The "F1" error code means a problem with the control board or the touch pad.
It can not be turned off unless the problem fixed.
Unfortunately both parts are no longer available.
If the part is no longer available is there anything that can be done or do I have to get rid of the oven.
Maybe it is sitting on a shelf somewhere but how you can find it?
Most likely you have to think about a new oven.
