washer starts working good but it wont drain out and it shuts off, please if you have any advice on my situation please let me know i would really apreciate it.
Hi Jaime,
I need more detailed description of the problem.
Drain pump is defective,this machine use an electric pump, small objects like paper clip and coins left in pockets find their way into the pump and prevents the impeller from turning,small panties like(thongs) and socks also find their way into the pump,another thing that i find in the pump from time to time is the piece of half moon shape wire that come from in the bra,once it find it's way in the pump it will stop it from working, also if you wash old rugs in this machine the rubber from the back will flake off and clog up the pump.
im jus trying to help my neighbor who is trying to fix it. She says that when the cycle starts it starts washing normal, but when its time to drain it just starts making a clicking noise and the washer turns off.
thank you, i took it apart and the pump was clogged with lots cotton left from clothes. I put it back together and it drains out now. Thank you for your help i really apreciate it.
Thank you Gene. I took the pump out and it was clogged with alot of cotton. Now it works perfectly and drains out.
We're glad you were able to fix it.
