My dishwasher is leaking where the motor connects into the pump housing. What part do I need to repair this?
The pump is leaking through the seals. You can replace the seals and impeller on the old pump or replace the whole pump and motor assembly. Both of them have the installation instructions. - The part number for the impeller & seal kit is AP631386 - The part number for the pump & motor assembly is AP2616850 In order to do the repair the dishwasher has to be removed from the cabinet. Gene.
