The touch sensors on the Dacor stove surface do not always work, i.e. sometimes don't turn on and once on sometimes don't adjust or turn off. Does anyone know how to repair. There is a printed circuit board for the sensor; could this be the issue?
Thanks.
Lou D
Hi Lou,
Most likely the whole glass has to be replaced due to the touch pad is a part of it.
In order to supply the right part number for the glass assembly I need the rest of the model number.
