I have order the upper clothes mover for my Whirlpool clothes washer. It does not seem overly difficult to replace. However, there are two or three removable parts. It appears that they do come with the cylinder. Do they come with the cylinder and is there any type lubricant needed? If lubricant is needed, does it come with the parts. What type lubricant is needed?
Originally Posted by: glen65  Thanks for info about the grease. Is "the dogs" an internal part or another part that doesn't come with the top agitator?
Originally Posted by: JimClarence  Thanks for info about the grease.
Is "the dogs" an internal part or another part that doesn't come with the top agitator? The dogs are what provide the ratchet action so that the mover only turns in one direction to push the clothes into the lower agitator. They are the most common item in the agitator to fail. The last time I actually ordered a clothes mover they did not come with it.
