AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Kenmore Dryer makes humming noise and shuts off intermitently
When I turn it on it hums for about 10 seconds and shuts off. It repeats this again about every 10 minutes. Does not turn on the heat, blower or rotate drum. Manually, I can rotate the drum. About once every two weeks, it will come on and work perfectly.
Usually this is your motor going south |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman usually this is your motor going south ditto!!!!!! tom
Dryer Repair
