Our refer keeps clicking like it is trying to do something. Everything seems to be working fine on it, keeps it cool and ice maker works properly. No water leaking out. Any ideas why it clicks?
It is clicking several times a day and I dont know where its coming from. My husband thinks it might be the compressor? Originally Posted by: Gene
If it clicks ones at the time when the compressor starts and there are no any other unusual noises then it can be considered as normal.
It clicks multiple times for about 2 minutes or so. It didnt do it before. Still normal? Originally Posted by: Gene  If it clicks ones at the time when the compressor starts and there are no any other unusual noises then it can be considered as normal.
Originally Posted by: zeusdog  It clicks multiple times for about 2 minutes or so. It didnt do it before. Still normal? Sorry for the delay. It can be a sign of a problem with the compressor start up. I would not do anything at this time, just watch it close. Gene.
ok, thanks. Originally Posted by: Gene  Sorry for the delay.
