fernando jr
#1 Posted : Saturday, September 26, 2009 12:22:01 PM(UTC)
fernando jr
the other one i put up was my washer thats ok this is my dryer wont heat clothing it runs good but just whont heat nead help on what part to change on it if you can help me that be cool ty
#2 Posted : Sunday, September 27, 2009 3:33:39 AM(UTC)
Your Model Number was not complete so the following info is for a PQ0
Replacement parts for WHIRLPOOL LER5636PQ0 | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/d...0Sheet%20-%208528187.pdf
Could be a number of things at the top of the list are.
1. Power, turn the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heater requires the full 240 volts. Better yet check/measure the voltage with a meter.
2. Heater could be burned out often you can see the broken element. Also can be checked with a meter.
3. Heater fuse is blown. This is the one on the heater itself. Again can be checked with a meter.
Here is agood site with basic dryer repair info.
http://www.applianceaid.com/dryers.html
Always unplug the unit when working on it. 240 volts is lethal.
