2 Pages<12
AngeloMangelo
#11 Posted : Saturday, September 26, 2009 3:19:09 PM(UTC)
AngeloMangelo
THe model number of the Amana is :
BX21VE
MFG: P1325014W B
Thanks Gene!
#12 Posted : Saturday, September 26, 2009 3:21:56 PM(UTC)
You are welcome. Here are the breakdown diagrams and Replacement parts for AMANA BX21VE | AppliancePartsPros.com
rebar
#13 Posted : Monday, September 7, 2015 1:24:21 PM(UTC)
rebar
I know this a old thread.. But I'm having the same problem with my Amana TZ18QW
It always dripped water into the bottom of the fridge and sometimes spilled over and out the door instead of draining to the pan. I figured the drain tube was plugged with crap, but after I turned the unit off, I see water now draining from the tube into the pan underneath after 24 hours off. It must have been frozen but I cant see the drain, but its not plugged anyway...
What component of the defrost system should I test?
UserPostedImage
2 Pages<12
