melangman
#1 Posted : Sunday, January 27, 2008 2:04:53 PM(UTC)
melangman
This unit shuts down on me after 2 minutes. After about five minutes it comes back on but you then have to reset the time and again it shuts down in just over 2 minutes. Any body know what might be wrong?
Mark
#2 Posted : Monday, January 28, 2008 10:10:54 AM(UTC)
Hi Mark,
Most likely the problem is a faulty cooling fan inside the microwave.
If the microwave is less then a year old, it should be under the manufacturer warranty.
melangman
#3 Posted : Thursday, January 31, 2008 8:32:54 AM(UTC)
melangman
Thanks Gene,
I contacted Magic Chief but they didn't have a repair service near me so I was told to cut off the cord and return it for a refund. Which I will do, but... being frugal and not wanting to throw out a 2 month old Microwave I would like to try to fix it. I will take the unit apart this weekend and see what's up with the fan?
While I have it apart is there anything else I should be looking for?
I will let you know how I make out and thanks for your advice!
Mark
#4 Posted : Thursday, January 31, 2008 10:38:53 AM(UTC)
Hi Mark,
Post your findings after you will check it.
melangman
#5 Posted : Monday, May 5, 2008 6:10:19 AM(UTC)
melangman
Thanks Gene!!
I FINALLY found the time to take the unit apart and found the fan housing had cracked and was blocking the fan blade, just as you had advised. I repaired it and it works perfect.
Thanks again,
Mark
#6 Posted : Monday, May 5, 2008 11:10:02 AM(UTC)
I'm glad you were able to fix it.
GE Microwave shuts down during use (Microwave Repair)
by rogera 3/4/2011 3:53:34 PM(UTC)
microwave shuts down during use (Microwave Repair)
by Lexus4mom 3/2/2011 10:29:12 AM(UTC)
microwave shuts down after about one minute (Microwave Repair)
by rmcgrew 4/13/2010 10:05:28 AM(UTC)
Microwave shuts down after 2-7 seconds requests to reset (Microwave Repair)
by trickponies 2/7/2009 1:19:41 PM(UTC)
Jenn-Air Microwave Shuts Down (Microwave Repair)
by bheitzen 8/22/2008 5:47:01 AM(UTC)
