Side by Side, is running every time I'm in there, fridge side not cool enough, I've unplugged the unit about two month's ago worked fine until now, looking for what part to replace
If the freezer side is cold enough and just the fresh food is too warm , check that the vent between the freezer and fresh food is open.
Since you say that it is constantly running could be that te freezer is not getting down to the correct temperature.
Check that the condenser coils are clean. Check that the compressor fan is running. Remove the covers and check that the evaporator coils have an even coating of frost. If there is just frost on one area (usually where the freon enters the coil from the compressor) , it is an indication of low freon. Check that the evaporator fan is running. |
THIS FORUM IS DEAD!!!!!!! |
