TonyRoy
#1 Posted : Sunday, January 27, 2008 5:40:50 PM(UTC)
TonyRoy
While roasting a Duck last night the control panel went completely blank. The oven was on at the time and did not shut off. However the temperature control was lost since the panel went blank. The oven burner was on and the only way to get it off was to shut the gas off to the unit and let it cool down.
We have been able to use the stovetop without any problems and the electric ignitors work.
I was looking at the parts listing on the whirlpool web site and noticed a
P/N 8523000 Jumper w/Fuse. Could this be the problem? Can I check it easily without taking the oven too far apart? If the fuse is good what else should I check.
Thanks for any help.
RegUS_PatOff
#2 Posted : Sunday, January 27, 2008 6:07:58 PM(UTC)
RegUS_PatOff
TonyRoy
#3 Posted : Sunday, January 27, 2008 7:42:12 PM(UTC)
TonyRoy
Thanks for the wiring diagram. I will be checking the voltage tomorrow and hopefully find the problem. I will let you know
Thanks again
Tony
TonyRoy
#4 Posted : Monday, January 28, 2008 10:12:05 AM(UTC)
TonyRoy
I checked the power at the plug and it was good so I went to check the power to the various circuits. When I plugged the oven back in the screen came back and everything works just fine.
Thanks for the help
Don't know why it shut off but at least it is working now.
Control Panel went blank (Oven Repair (including Ranges and Cooktops))
by tkchase 1/5/2016 8:43:58 AM(UTC)
Control panel went blank but burners still work (Oven Repair (including Ranges and Cooktops))
by LOL in MD 2/25/2009 2:01:29 PM(UTC)
