aduke
#1 Posted : Sunday, August 12, 2007 6:13:42 PM(UTC)
aduke
I cant seem to get my water to come out .
i have cleaned the water lines with a air compresor and checked the switch on the door.AT first it was taking a long time to come out then it stopped altogether.ANy ANSWERS:o
ApplianceJunk
#2 Posted : Sunday, August 12, 2007 7:08:07 PM(UTC)
ApplianceJunk
Do you have good water pressure to the refrigerator?
aduke
#3 Posted : Monday, August 13, 2007 6:25:36 AM(UTC)
aduke
I have been useing it for 3 years no change. in water pressure
Any other ideas Thanks
ApplianceJunk
#4 Posted : Monday, August 13, 2007 6:41:11 AM(UTC)
ApplianceJunk
If your are sure that you have good water pressure to the refrigerator I would then replace the water valve.
aduke
#5 Posted : Monday, August 13, 2007 7:04:56 AM(UTC)
aduke
can you recommend a place to buy the parts
ApplianceJunk
#6 Posted : Monday, August 13, 2007 9:06:52 AM(UTC)
ApplianceJunk
Appliance Parts Pros.com Discount Appliance Parts – Appliance Repair Parts
parvaaz
#7 Posted : Tuesday, January 1, 2008 3:40:25 PM(UTC)
parvaaz
I have a side by side whirlpool refrigerator. I am having similar problems with my refrigerator. I replaced the water valve and there is still no water. The water does flow from the main line to the filter to the intake valve with pretty good pressure. Since nothing happened after replacing the valve, I removed the outlet lines from the valve to see if water comes out of it, but there is no water at all.
I have been trying to resolve this problem for several days but nothign seems to work. Any help would be greatly appreciated.
piperdre
#8 Posted : Tuesday, February 3, 2009 11:28:06 AM(UTC)
piperdre
I am also having issues with my water dispenser, I want to test the switch, but I am having a dickens of the time removing the front panel. According to what I have read I am supposed to be able to gently pry it off with fingers.
All I have been able to do is pry it enough to give a small hairline crack. Any ideas for a Kenmore S/S Coldspot Mod. 10657573790?
