My dishwasher will fill but the wash and drain cycles won't turn on -- just clicking noise. I removed control board and found 2 resistors were hot to touch and the board was discolored where they are located (R301 & R302)
It looks like they could be the problem. Do I need to replace the whole board or can I just replace the resistors. Where can I find a new control board if it needs to be replaced? There is a number on the board 60D20960401. Thank you for your service.
Here are your parts includes a wiring diagram Replacement parts for MAYTAG MDB7130AWS | AppliancePartsPros.comI would check the following first http://www.servicematters.com/m...ary/docs/TDD-0011B-B.pdfIt looks like they could be the problem. Do I need to replace the whole board or can I just replace the resistors. You would have to replace the board. The resistors are probably OK since they are heating up somewhat, we know current is going through them. I cannot get schematics of the boards so cannot troubleshoot down to component level on them. I would remove the plug from the motor and check it with a meter to ensure the windings are OK. Also check that it is not jammed up. Where can I find a new control board if it needs to be replaced? See the parts link. |
THIS FORUM IS DEAD!!!!!!! |
