2 Pages12>
bubby
#1 Posted : Wednesday, September 23, 2009 12:24:59 PM(UTC)
bubby
I purchased a new igniter part # 12400035 i have installed it,and it is not glowing. I have power to the igniter and power to the valve.
#2 Posted : Thursday, September 24, 2009 11:43:32 AM(UTC)
How did you check power to the igniter? What was the reading? Did you check the igniter for continuity?
bubby
#3 Posted : Thursday, September 24, 2009 3:32:12 PM(UTC)
bubby
I checked power with a voltage meter. The meter indicated 120v. I have checked continuity now, however I assumed continuity was ok with 120v at the valve.
#4 Posted : Thursday, September 24, 2009 9:51:42 PM(UTC)
Quote:
...I have checked continuity now, however I assumed continuity was ok with 120v at the valve...
I'm afraid I did not get it clear. Have you disconnect the igniter and checked it for continuity?
bubby
#5 Posted : Friday, September 25, 2009 1:19:54 PM(UTC)
bubby
Yes, I have disconnected it and checked it for continuity.
#6 Posted : Friday, September 25, 2009 1:30:10 PM(UTC)
If there is 120 VAC to the igniter while the control calls for heat, and the igniter has continuity then it must glow.
Might be there is something wrong with the tests you performed or their descriptions you posted.
bubby
#7 Posted : Saturday, September 26, 2009 1:36:15 PM(UTC)
bubby
I don't think I have performed the test wrong. I think I have a bad igniter. However, Appliance parts pros will not replace it without your approval. However, I am willing to try something different if you give me a suggestion.
#8 Posted : Saturday, September 26, 2009 2:58:16 PM(UTC)
What is the exact resistance reading of the igniter?
bubby
#9 Posted : Saturday, September 26, 2009 4:04:21 PM(UTC)
bubby
I'm not sure how to read resistance,I have cheap multitester with 1k ohms.the reading is between 0 and 1, with 5 divisions between 0 and 1. The needle reads between the first and second division.I would call it .30
#10 Posted : Saturday, September 26, 2009 7:49:20 PM(UTC)
Sounds like the reading is about 300 Ohms which is good.
Can you unplug the igniter wires and retest the voltage?
2 Pages12>
