I know I may sound odd. But can you tell me which direction you turn the 1 inch brass nut on the gas valve to loosen it. When I have the 1 inch wrench thru the access door should I turn the wrench up or down to loosen the gas valve nut. Frustrated. Thank you. George Mike.
