i am working on a maytag front loader that will let water go into system, but when it's time to tumble tub tries to work, but whole system will just cut off. any ideals where to start?
does door lock light come on? unit will not spin if not locked.If not lite unplug unit open top control three screws on to and roll control forward. look on main board somewhere in middle of control there is a small blue block about 1/4"x1" right above that is there a resistor blown?
