JimGarland
#1 Posted : Wednesday, September 23, 2009 3:25:10 AM(UTC)
JimGarland
Just replaced the Motor coupler due to the machine not agitating/spinning. Motor now works, but the machine will not stop filling water at the desired load level setting. ie..have load level set to small and it fills up to the top, almost over flowing. Any ideas as to what I missed? All connectors are connected.
JimGarland
#2 Posted : Thursday, September 24, 2009 5:21:18 AM(UTC)
JimGarland
I reseated all connections at the motor base, Control panel, and reseated clear hose from the side of the tub to the control panel. Now working.
