vbandpb
#1 Posted : Sunday, January 27, 2008 9:05:48 AM(UTC)
vbandpb
Can anyone help with my dryer..It is about a year and a half old and now won't heat and it doesn't stop running.
#2 Posted : Monday, January 28, 2008 9:07:20 AM(UTC)
The first thing I would check is 240V at the power outlet.
If there is nothing wrong with the power then the following parts have to be tested for continuity:
1. The heating element (#17 on the break down diagram)
2. The thermal cut-off (#6 on the break down diagram)
3. The hi limit thermostat (#15 on the break down diagram)
4. The cycling thermostat (#24 on the break down diagram)
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter – How to check continuity with Ohmmeter.
- The part number for the heating element is AP3094254
- The part number for the thermal cut-off (including the hi limit thermostat) is AP3094244
- The part number for the hi limit thermostat is AP3131941
- The part number for the cycling thermostat is AP3131939
Good luck.
JohnOz
#3 Posted : Monday, January 28, 2008 10:45:23 AM(UTC)
JohnOz
What about a Roper RGX5634KQ2, Gas Dryer, that won't heat up and doesn't stop running?
#4 Posted : Monday, January 28, 2008 6:54:37 PM(UTC)
Hi John,
You can find the complete instructions in the one of my previous posts: http://forum.appliancepartspros...3-no-heat-gas-dryer.html
Here are the break down diagrams for the Roper dryer Model RGX5634KQ2
Guest (5)
