Getting Gas To Oven Gas Valve , Valve Is Brand New , Getting Electric To Valve , Glow Ignighter Working, No Gas Comming Through Gas Valve. Now Can You Help Me To Diagnose The Problem.
Very likely the problem is a bad igniter even if it does glow. If the current drawn by the igniter is less than 3.2 amps then it is not enough to open the gas valve. - The oven igniter Part number: AP2020569
