gbir
#1 Posted : Wednesday, September 23, 2009 5:32:03 AM(UTC)
gbir
This is for a Frigidaire Washer - Top-Loading, Model No. FWS845GCS0.
On this model the belt is on the very bottom and drives the pump and transmission. There seems to be a spring loaded idler pulley hard to see or get at from the front (front panel off).
The belt squeals loudly and seems a bit loose. A dose of belt dressing quiets it down for several loads but the squeal comes back. Maybe the belt has streched?
Is there a way to tighten the belt or is the tension from the spring loaded idler pulley the only tightening method allowed?
What is the proper procedure for changing the belt?
sidfink43
#2 Posted : Thursday, September 24, 2009 2:57:10 PM(UTC)
sidfink43
I would change out the belt and the idler assembly/spring. The idler is the only way to adjust tension. If you release tension on the belt you should be able to "roll" the belt off.
