cbkenney
#1 Posted : Tuesday, September 22, 2009 6:02:04 PM(UTC)
cbkenney
When we started our dryer tonight the dryer drum is rubbing and making a terible noise. Could this be a belt issue. I do not have the manual, is there a way to locate one?
SublimeMasterJW
#2 Posted : Tuesday, September 22, 2009 7:31:08 PM(UTC)
SublimeMasterJW
Unplug the dryer and remove it to the yard if possible. Start here:
UserPostedImage
Start here
UserPostedImage
Older models need to have this clip removed(yer we3x75 goes there)
UserPostedImage
we3x75 drum bearing
Remove the screws:
UserPostedImage
Lift the front out yer way
UserPostedImage
Inside the dryer:
UserPostedImage
Note location of non-resetible limit (if bad dryer will not run)
A broken heating element:
UserPostedImage
Broken dryer element (can easily be restrung)No need to buy the whole new pan!
UserPostedImage
A good look at how dat belt oughta be if installed all propah.
GE Harmony Dryer Manual
