pyrman
#1 Posted : Tuesday, September 22, 2009 12:38:21 PM(UTC)
pyrman
Maytag dishwasher model #MDB8600AWB,"rinse" button only will light,flash number 9 and then go off.Is the flashing 9 a code?Will not turn on.
#2 Posted : Wednesday, September 23, 2009 1:15:25 AM(UTC)
Replacement parts for MAYTAG MDB8600AWB | AppliancePartsPros.com
Here is a service manual and tech sheet
http://www.servicematters.com/m...ibrary/docs/16021814.pdf
http://www.servicematters.com/m...ibrary/docs/16026390.pdf
Run the diagnostics.
Often a flashing light indicates a stuck key.
This is usually the keypad but can be the control board.
Only way to be sure is to check the keypad with a meter (see the tech sheet)
emanofoz
#3 Posted : Tuesday, October 27, 2009 8:20:08 PM(UTC)
emanofoz
The PDF files are almost exactly what I needed but my model MAYTAG MDB8600AWB (Quiet Series 300) Dishwasher, serial number 16450574CG, has 18 pins on the J1 jumper and I didn't find the technical materials behind the toe panel as was stated in the manual.
Please, I was hoping you could find the proper tech pdf's for my model/series. If you can it would help so much. I just replaced the control board last October (1 year ago) and I think the start button on the membrane is my problem this time.
Told my wife I'd spend the money to fix it one more time and if next year I have to do this again I'll opt for a new dishwasher and a different brand. (Sorry for the rant.)
Thanks again for being there for us out here.
Eman
Originally Posted by: denman Go to Quoted Post
#4 Posted : Tuesday, October 27, 2009 11:50:48 PM(UTC)
Here is a different tech sheet that specifically lits the MDB8600AWB
http://www.servicematters.com/m...ibrary/docs/16023220.pdf
This is all that is available, well at least all I can find.
If only a couple keys are shot try the following:
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
emanofoz
#5 Posted : Wednesday, October 28, 2009 2:23:39 PM(UTC)
emanofoz
This sheet also only goes to 12 but I am thinking that they are only showing the points you are to test and not the other points which are not going to be tested anyway. What do you think? Thanks for replying so quickly.;)
Eman
#6 Posted : Wednesday, October 28, 2009 5:21:14 PM(UTC)
Yes,they do not show the irrelevant ones for instance the lines used to power the display.
saintandre
#7 Posted : Sunday, July 20, 2014 11:50:52 AM(UTC)
saintandre
I must admit I am a novice but would like to consider myself "handy" at times. In reading your thread I was able to fix my dishwasher problem. My dishwasher was stuck on Rinse cycle. I tried a few troubleshooting ideas with no luck. I then removed the ribbon cable from the board and cleaned it with an alcohol wipe, reconnected it, and now is working! Thanks for your ideas!!:)
Guest (5)
