I Have A Rolling Frigidaire Dishwasher That You Connect To The Faucet On The Sink. Its Not That Old. Im Not Getting Any Water. I Already Replaced The Water Inlet Valve And Still Not Working. Am I Missing Something Else That I Cant Think Of? Please Help.
The first thing to check is the float it may be stuck. See # 25 in pic below. It should move freely up and down. When you raise it by hand the float should drop down when you release it.
I Have Checked To See If The Float Or Switch Were Sticking, But They Are Both Good. I Even Check For Cont. On The Switch And It Is Good.
The next thing to do would be to pull the plug off of the fill valve then insert the probes on your meter so that they make connection to the terminals. Set your meter to measure AC voltage then start it on a cycle. At some point for a brief period after you start it you should get 120 volts AC. Do you?
