I have a Whilrpool Conquest Gold seriese side by side frig Model #: GS6SHEXNL00. It started to make clicking noise from the back/bottom of the frig when I open the frig side. All 3 light stopped working on the frig side but the freezer side lights are working fine. I replaced one of the light bulbs but that did not help. When I remove all three frig bulbs, the clicking noise stops. I tested all the bulbs and all are good. So now I have a dark frig which otherwise is working normal. I opended up the frig back side and the only thing I see that I can replace is the circuit board for $73. I see that there are 3 non-removalable 24v transformers on the board, I think one of them is bad. Any adivce...
i have the same problem too, it just started today. i was wondering if you figured out what the problem was. thanks joe.
