JOE BLACK
#1 Posted : Saturday, September 19, 2009 1:39:36 PM(UTC)
JOE BLACK
Dryer rans but no heat.
sidfink43
#2 Posted : Monday, September 21, 2009 5:52:30 AM(UTC)
sidfink43
First check to see that you hav 120v to each side of the connection block.
Then unplug the machine and check for continuity in your thermostats/thermal fuses. The most likely problem is in the thermal fuse. Here is the part.
Part number: AP3132867
Finally, if these are not the problem check the heating element for resistance and continuity.
While you are in there, thoroughly clean out the machine, including the vent, the lint chute and the blower wheel.
Good luck.
