deamit1
#1 Posted : Monday, September 21, 2009 3:55:34 AM(UTC)
deamit1
has power and fuse is ok.wife was canning on stove says fan came on and would not stop eventually turned off. tried to use micro later and would not turn on?
#2 Posted : Monday, September 21, 2009 8:30:09 PM(UTC)
Does it do anything? Does it make any noises? Does it show anything on the display? Does it count down when you push the start button?
There are suppose to be two more digits in the model number.
deamit1
#3 Posted : Tuesday, September 22, 2009 5:01:00 AM(UTC)
deamit1
no does absolutley nothing as far as model # JVM1653SH 06 if that helps thanks.
