thecyclo
#1 Posted : Friday, November 9, 2007 6:15:59 AM(UTC)
thecyclo
I recently moved into a house where the dryer worked for a couple of loads and then simply would not turn on when a new load was placed inside. I do not know if the problem is in the switch or the moter. Everytime I press the switch nothing happens.
jose
#2 Posted : Tuesday, November 13, 2007 4:22:47 PM(UTC)
jose
I have a roper dryer and recently just stop heating.Would somebody help me
and tell me whats wrong with it?:cool:
#3 Posted : Wednesday, November 14, 2007 4:22:24 PM(UTC)
In order to provide the most accurate advise I need the complete model number of your dryer. You can find it on the door frame.
Please, post it as a new thread.
Dennis331
#4 Posted : Friday, January 25, 2008 3:16:14 PM(UTC)
Dennis331
I have a roper dryer electric that I turned on when I went to work last night it dryed everything, My wife got up at 3 am and the dryer was still running but with no heat. I have it running now no heat.
Mod #MR5044615
I will be going to work in a little while, if you wouldn't mind sending help to my e mail, if not that is ok
den44@juno.com
#5 Posted : Saturday, January 26, 2008 3:19:23 PM(UTC)
Hi Dennis,
What cycle did you use when it was running nonstop?
Looks like instead of the model number you posted the serial number.
Verify and repost it, please.
Dennis331
#6 Posted : Sunday, January 27, 2008 4:45:41 AM(UTC)
Dennis331
Roper dryer is Ser#REX3514PQ0
TYPE D433-ELE 2406028-FM54
It says the auto sense dry side of the dial, which is on the left side.
Dennis Langer
den44@juno.com
#7 Posted : Sunday, January 27, 2008 10:20:04 AM(UTC)
Hi Dennis,
On the same name plate where you found the serial number suppose to be the model number.
Dennis331
#8 Posted : Sunday, January 27, 2008 1:06:53 PM(UTC)
Dennis331
Mod #MR5044615 I believe this is the Mod #
Guest (7)
Roper dryer repair (Dryer Repair)
by zoo 8/16/2010 11:16:46 AM(UTC)
