My dishwasher wasn't draining properly. Took it apart to take a look and in the process either broke or found broken, a tiny black plastic piece that fits onto a metal arm at the base of the dishwasher. From what I can tell, the metal piece rotates and this plastic piece which has a little arm protruding from it, lifts a seperate metal springed arm, which triggers the drain in the center of the circular filter above (make sense at all). How to replace control module.doc (25kb) downloaded 31 time(s). My questions then are where do I find this part, how do I reattach it properly, and, if neither of those things are possible, can I get away without this thing. Thanks, Aaron AaronW attached the following image(s):
A Model Number may help identify this part |
THIS FORUM IS DEAD!!!!!!! |
