Schaffer
#1 Posted : Sunday, September 20, 2009 4:29:47 AM(UTC)
Schaffer
Drying was operating and then siezed and stoped. I manually turned the drum a few times. It operates again, making a "clinging" and scratchy sound. belt? bearing? I'm clueless. Please suggest a diagnosis and a method of repair. Thank you.
I should add that when the original siezing occurred the load was small, a table cloth and a pair of tennis shoes.
#2 Posted : Sunday, September 20, 2009 4:45:40 AM(UTC)
Your Model Number looks to be short a couple digits.
The original problem May have been something that jammed between the drum and the frame.
Run your fingers around the ends of the drum where it meets the frame to see if something is still stuck in there.
Be careful in case it is sharp.
Also check the paddle in the drum to see if it is loose.
If the above is OK you will have to open it up to see what is wrong.
Try to find the general location of the clink (front/back/left/right etc.) so you have an idea where to look
Schaffer
#3 Posted : Sunday, September 20, 2009 4:54:52 AM(UTC)
Schaffer
I checked around the drum, on the frame and could not find anything causing a stick. The drum moves well right now. How do I check the paddle? The noise comes from the back of the dryer, although I can't say if it top or bottom.
Schaffer
#4 Posted : Sunday, September 20, 2009 10:15:58 AM(UTC)
Schaffer
The correct model number is LER8857EQ1
#5 Posted : Sunday, September 20, 2009 10:36:06 AM(UTC)
Replacement parts for WHIRLPOOL LER8857EQ1 | AppliancePartsPros.com
Just jiggle the paddle to see if it is loose.
Sounds like you will have to open it up
Here is a good site with dryer repair info
http://www.applianceaid.com/dryers.html
