our dishwasher will fill with water and do nothing else. The timer counts down, but nothing happens after filling. It will not drain. We have just replaced the contorl board (today) afteer findin a couple of burnt resistors on the old board. The board does make a click sound every so often. Any help would be greatly appreciated. AppliancePartsPros say the board cannot be returned. Thanks
THIS FORUM IS DEAD!!!!!!! |
After reading your Tech Bulletin, where do I find the date code? I will check the motor as well. Thank you for your quick reply.
