Teager
#1 Posted : 15 years ago
Teager
I put the oven in self clean mode and about half way through an F2 code appeared and the fan was running. Initially I thought it had just over heated but when I looked the code up it said "shorted thermal sensor" I checked the sensor in the middle of the oven once it had completly cooled down and there was no short to ground on either lead, however when I checked the one on the right that has leads to the fan motor it do show a short to ground on one leg. Any help or suggestions would be greatly appreciated. Thank You
Teager
#2 Posted : 15 years ago
Teager
Is there anybody out there that may know why one of my sensors shots to ground ?
Whirlpool Gas Range F2 code (Oven Repair (including Ranges and Cooktops))
by Cookie NJ 12 years ago
