rlawrence
#1 Posted : Thursday, January 24, 2008 5:06:50 AM(UTC)
rlawrence
I have a four burner, gas, Thermador cooktop. As soon as the unit is plugged in, all four ignitors start to click. If I turn one, or all, of the burners on, it lights, but the ignitor continues to fire. Right now, I am using the unit by leaving it unplugged and lighting it with a match. Any ideas? Ron
kawfeeman
#2 Posted : Thursday, January 24, 2008 6:02:14 AM(UTC)
kawfeeman
more than likely one of the switches that are on top of the valves are shorted closed ... plug the unit in, turn one burner on at a time, and see which burner causes the sparking to stop. if you none of the burners being on stops the sparking, there is a possibility that your spark module is being told to send spark due to a shorted wire ... any major spills recently ?
rlawrence
#3 Posted : Thursday, January 24, 2008 9:49:07 AM(UTC)
rlawrence
Did I say four burner? It's actually five and yes, one of them did make it stop sparking? Feels like progress. Now what? Thanks for the help. Ron
kawfeeman
#4 Posted : Friday, January 25, 2008 5:13:54 AM(UTC)
kawfeeman
change the switch that corresponds to the burner that made the clicking stop .. your switch is shorted / stuck closed...
rlawrence
#5 Posted : Friday, January 25, 2008 6:52:24 AM(UTC)
rlawrence
That's great. Thanks. Now, being new at this, is the switch located near the knob that turns the gas on and off, or near the burner? I haven't opened it up yet. Will it be obvious once I do? Ron
kawfeeman
#6 Posted : Friday, January 25, 2008 7:15:01 AM(UTC)
kawfeeman
with the power off, after removing main top, will need a socket set, replace switch on top of the valve that you turn to let gas go to the burner ... parts can be acquired direct from manufacturer ( btw: which burner did you find that stops the sparking ? )
rlawrence
#7 Posted : Friday, January 25, 2008 2:29:39 PM(UTC)
rlawrence
It was the front left burner. You were right on the money. As soon as that switch was removed, everything worked fine. I have the part ordered. Thanks for the assistance. Ron
