bwcw12266
#1 Posted : Thursday, January 24, 2008 5:50:01 PM(UTC)
bwcw12266
I started the washer on "light wash" and it made a funny noise when it started filling with water. I canceled the cycle and the washer drained. I restarted it on "normal wash," it started to fill but it would never start the wash cycle, but it will drain. What could be the problem? Thanks for your help.
#2 Posted : Friday, January 25, 2008 2:10:39 PM(UTC)
Does it make any unusual noises?
If it does, can you describe the noise and where it's coming from?
bwcw12266
#3 Posted : Friday, January 25, 2008 5:32:00 PM(UTC)
bwcw12266
No, it doesn't make any unusual noises. It sounds like it wants to run but can't. Any suggestions?
#4 Posted : Saturday, January 26, 2008 3:50:05 PM(UTC)
Remove the bottom panel and check for a slow water leak through the pump which could cause rust to the motor bearings.
In such case you have to order the pump & motor bushing assembly together with the pump seal/impeller kit.
If there is nothing wrong then possible a foreign object stuck inside the pimp.
- The part number for the pump & motor bushing assembly is AP178769
- The part number for the pump seal/impeller kit is AP178753
Here are the break down diagrams for the Jenn Air dishwasher Model JDB3610AWX
gbousa
#5 Posted : Sunday, March 16, 2008 9:04:05 AM(UTC)
gbousa
i am havingsomewaht of the same problem.dishwasher turns on then stops after a minute. water drains. did you determine fix
#6 Posted : Sunday, March 16, 2008 11:22:53 AM(UTC)
Hi gbousa,
What is the model number of the dishwasher?
bwcw12266
#7 Posted : Sunday, March 16, 2008 7:17:00 PM(UTC)
bwcw12266
Hi gbousa,
The repairman took the dishwasher apart and found two little pieces of hard plastic that was keeping it from running properly. At first, I couldn't figure out where the plastic came from, but after searching my utensils, etc. I found the cheese grater had broke and the pieces got down in the washer. It cost me $156 to get it fixed, but it works fine now. Good luck.
Guest (4)
