steviebinto
#1 Posted : Thursday, September 17, 2009 2:39:18 PM(UTC)
steviebinto
I have a stackable Kenmore washer dryer and the dryer is not heating up. Everything else works but this. I have replaced both thermostats but it still is not heating up, coils look good. Any suggestions.
sidfink43
#2 Posted : Sunday, September 20, 2009 10:36:03 AM(UTC)
sidfink43
You have not posted a model number, but I assume this is an electric unit.
Check to make sure you have 120v going to each side of the connection block.
I am not sure how many thermal fuses/thermostats you have because you did not post a model number, but make sure all of them check out for continuity with a meter.
Then use the meter to check resistance on the heating coils and make sure they are not gounded to the unit.
This should do it.
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 11/22/2020 12:41:02 PM(UTC)
Kenmore Dryer Problem (Dryer Repair)
by johna56 4/17/2011 3:26:13 PM(UTC)
