gomabus
#1 Posted : Wednesday, January 23, 2008 5:10:07 PM(UTC)
gomabus
I have a window unit that heats and cools. I notice a burning smell the last couple of nights. I thought it was coming from the outside. I notice the unit was running (fan) but not heating tonight. I then tried to turn on the ac it would blow but the compressor would not turn on. any suggestions?
#1 tech
#2 Posted : Thursday, January 24, 2008 8:40:00 AM(UTC)
#1 tech
Sounds like maybe some control wireing shorted out. Have you opened up the unit? Is there any obivous damage? How much was the unit new?
gomabus
#3 Posted : Thursday, January 24, 2008 9:39:17 AM(UTC)
gomabus
I took the front panel off. Did not notice any wiring issues. I will take a indepth look. I was thinking it may be the thermostat conteol
#1 tech
#4 Posted : Thursday, January 24, 2008 1:13:37 PM(UTC)
#1 tech
You can ohm out the thermostat control and see if it is closeing or opening as it should. If you have a meter.
