kosamson
#1 Posted : Wednesday, September 16, 2009 6:29:49 PM(UTC)
kosamson
I have a Frigidaire model FRS6L9EFSS0 that quit making ice and dispensing water. I've replaced the filter. Just now, I raised the temperature to 5 degrees because I read in another thread that the freezer temperature should not be any lower than that. However, I'm not convinced that is the problem because the water dispenser and ice maker worked fine for three years with the freezer temperature set at 0 degrees. Any help is greatly appreciated. Thanks.
woodchuckie
#2 Posted : Wednesday, September 16, 2009 8:05:51 PM(UTC)
woodchuckie
Sounds like a water supply problem. Make sure the mesh screen on the water inlet valve is not stopped up and that you have water getting to the valve. You can test the water inlet valve with an ohm meter> How to check stuff>
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Guest (4)
