Johnwilson123
#1 Posted : Wednesday, September 16, 2009 4:59:15 AM(UTC)
Johnwilson123
None of the Top burners will not spark or ignite. I think it might be the spark module. The burners will spark and ignite for a couple of days if I disconnect all wires from the module and plug them back in. Can it be anything else other than the spark module?
Thank you
Frank / APP Team
#2 Posted : Wednesday, September 16, 2009 9:51:08 AM(UTC)
Frank / APP Team
Thank you
Check to see if you're getting 120v across the line wires on the module, (not the ignitor wires), when you turn on one of the burners. If you are, then the module is bad. If you aren't I think you need to check for a loose connection somewhere. Can't imagine all of your ignitor switches are bad.
Johnwilson123
#3 Posted : Wednesday, September 16, 2009 12:12:34 PM(UTC)
Johnwilson123
Thank you. I will check connections and voltage before I change the module.
John
Guest (4)
GE Profile Ignitor problems (Oven Repair (including Ranges and Cooktops))
by Brent Feathers 8/3/2012 8:54:02 AM(UTC)
