Juan Hinojosa
#1 Posted : Monday, September 14, 2009 8:03:30 PM(UTC)
Juan Hinojosa
Hello,
When on the spin cycle our Amana washer makes a loud noise that appears to be coming from the bearing. Beside the bearing what other parts will I need? I am assuming I will also need the drive bell seal which might get ruined when I take it off to get to the bearing. Anything else?
Thanks,
JH
sidfink43
#2 Posted : Tuesday, September 15, 2009 6:34:44 PM(UTC)
sidfink43
Hi Juan
Here is a tech sheet from Maytag that may help you.
http://www.servicematters.com/m...ary/docs/TDL-0023A-B.pdf
Good luck.
