something in the control console is squealing. Im guessing its an electric motor because I unplugged a wire on it and it stopped but it starts back up again when I plug it back in. Im not sure how old this refridgerator is because I just moved into this rental.
It's probably the damper control motor. Does it stop after a few seconds? If not, you may be hearing noise transmitted from your evaporator fan.
