cawhirl
#1 Posted : Monday, September 14, 2009 6:37:24 PM(UTC)
cawhirl
the waher works fine until it has to go to a spin cycle. during the spin cycle it will pump water out but the agitator remains engaged so it doesn't spin the tub.
#2 Posted : Tuesday, September 15, 2009 1:44:13 AM(UTC)
You have a busted solenoid plunger that activates the tranny slide bar.
cawhirl
#3 Posted : Tuesday, September 15, 2009 11:37:14 AM(UTC)
cawhirl
would that require pulling the motor and the transmission to replace? and is it a part I can buy.
Thanks for your help
#4 Posted : Tuesday, September 15, 2009 12:00:53 PM(UTC)
Flop the washer on it's face, remove the access panel, and turn the tranny pulley and belt while holding the solenoid plunger ( the one nearest the tranny spindle) down. You will probably find it will not move the slide bar and you have a busted pin in the plunger. If ok, and the agitator stopps agitating, you have busted wires to that solenoid.
cawhirl
#5 Posted : Tuesday, September 15, 2009 12:35:30 PM(UTC)
cawhirl
It is a direct drive system so there are no pulleys or belts.
#6 Posted : Tuesday, September 15, 2009 12:55:47 PM(UTC)
Your model # is missing some letters/numbers.
cawhirl
#7 Posted : Tuesday, September 15, 2009 1:30:59 PM(UTC)
cawhirl
you are right it is an LA7000XTW0
#8 Posted : Tuesday, September 15, 2009 3:35:11 PM(UTC)
Remove the outer cabinet, the pump and motor. Turn the tranny coupler clockwise and see if the agitator still moves back and forth. If so=new tranny time.
