Just purchased this oven used... had to convert to LP (was on Natural Gas). Overheats and then flashes the error of F3 E2? (not sure of the last two). Is this something we can fix or do we have to call a tech?
Originally Posted by: samnapril4  Just purchased this oven used... had to convert to LP (was on Natural Gas). Overheats and then flashes the error of F3 E2? (not sure of the last two). Is this something we can fix or do we have to call a tech? F3 E2 means there is an over temp condition caused by the oven sensor. It would also be a good idea to check the sensor wiring and connections.
where would we find instructions on how to do this? are we looking to replace a part/sensor or just looking for something that came 'loose'. could this problem have been caused by the move?
Originally Posted by: samnapril4  where would we find instructions on how to do this? are we looking to replace a part/sensor or just looking for something that came 'loose'. could this problem have been caused by the move? The sensor probe (see pic below) is fastened in from either the inside of the oven with 2 screws holding it to the liner. Or they stick it through from the back. I think yours is the latter method. You would need to cut the power and remove the back in order to gain access to it. Before you actually buy any parts check the sensor wires and any of their connections. Part Details - WHIRLPOOL Sensor, Oven, part number: AP4326911
