2 Pages<12
CathyG
#11 Posted : Monday, September 14, 2009 2:10:05 PM(UTC)
CathyG
Thanks again Gene. I am pretty sure you are right, and will give that a try before we do anything else.
So, I guess I just need to face the fact that we either need to replace the control board, or buy new! In your expert opinion, do you feel $500 + labour to repair an 11 year old range is not a good investment.. would I be better of buying new.. If I shop around I might find a new convection range with ceran/glass top for approx $700.
Your opinion would be greatly appreciated.
Thanks for all your help throughout. It has been very helpful and alway on the money!
Sincerely,
Cathy.
#12 Posted : Monday, September 14, 2009 4:50:30 PM(UTC)
Cathy,
If you can find a new compatible range for such price then buy it! No doubt about it.
Geoffcalgary
#13 Posted : Sunday, January 10, 2010 8:07:40 AM(UTC)
Geoffcalgary
Hello,
I have the same model of Kitchenaid range. It is a Canadian model. I seemed to have fixed the problem by disconnecting the ribbon cable to the control panel and then reconnecting the cable. I don't know how long the fix will last. I was surprised to see the poor quality of the inside of this range. There are a lot of scorch marks around the wiring as if they are overheating.
I got a quote to repair this at $435 for the panel plus $89 service call plus $85 per hour for labour.
I also replaced the gaskets around the oven lights, but I don't know if they seal out the moisture or not.
2 Pages<12
