2 Pages12>
cdnhawk02
#1 Posted : Monday, September 14, 2009 2:22:31 AM(UTC)
cdnhawk02
Views messages in topic : 10
Hello all.
I need your expert advice and help. I have a refrigerator that is cool but not cold and the freezer seems to be just fine. This is a Kenmore Model Freezer on top, fridge on bottom.
Currently I can feel some cold air coming through the vent in the fridge part, but the strength of the air flow isn't that strong. Is that normal? I can't find any manuals or parts break down based on my model info from the metal plate on the inside of the fridge.
I have already cleaned off the condenser line along with the fan at the bottom of the fridge. Another thing I have already read off this post and tried is removed the back cover inside the freezer and lubricated the fan with spray. The fan seems to be running fine now, previously I noticed that it wasn't running at all until I knocked on the plastic cover.
Please HELP! :confused:
Kenmore (made for Sears)
Model Number: 970-418529
Serial Number: BA60632450
About 6 years old approx.
Thanks in advance.
Jason
#2 Posted : Monday, September 14, 2009 3:45:12 AM(UTC)
Your Model number seems to be missing a couple digits
When you removed the evaporator cover in the freezer, what did the evaporator coils look like?
A light coating of frost or coils being clear (if you opened it up just after a defrost cycle) is normal. If the coils were heavily frosted/iced over you have a defrost problem. It will show up as a problem in the fresh food section first and later in the freezer.
If the coils are OK I would replace the fan sounds like it is on it's last legs.
If it is rotating slow it will not blow enough cold air into the fresh food section.
FYI your fridge is made by Frigidaire
Here is a good site with basic fridge repair help
http://www.applianceaid.com/frig.html
cdnhawk02
#3 Posted : Monday, September 14, 2009 4:18:02 AM(UTC)
cdnhawk02
Thanks for your help Denman. When I removed the evaporator cover yesterday there wasn't a heavy coating of frost or ice. But I will check again tonight. Also I will double check the model number, any other suggestions or checks for me to perform?
Where do I find the defrost timing clock control? As suggested in the sticky for this type of condition?
Thanks again in advance.
Jason
#4 Posted : Monday, September 14, 2009 6:20:09 AM(UTC)
Without being able to get a parts breakdown it is hard to say where the defrost timer is.
If it is the type of unit that uses a mechanical defrost timer it is often behind the kick plate or in the console at the top of the fresh food section.
If you look up at the console you will see a hole, this allows access to the timer's cam which can be rotated with a screwdriver to force a defrost cycle.
Note that it only rotates in one direction.
If it uses an adaptive defrost (electronic) it can be a separate board or part of the main control board.
I would lean more towards the fan. It may work OK when it is warmed up and lubricated but slow down once it gets frozen.
cdnhawk02
#5 Posted : Monday, September 14, 2009 3:54:50 PM(UTC)
cdnhawk02
Okay. So I have made it home and took a second look at the model number/serial number metal plate within the fridge it is correct. That's weird I guess I have a fridge that you don't have info on. Just my luck...
But I removed the back freezer panel to expose the evap lines and removed the fan assembly. I have taken some pictures below. Can you please clarify for me where the dampener should be? I looked inside the plastic "shoot" that comes down from the fan, I can see the plastic knob back end .. but no dampener at all>??
What I was able to pull off of the fan was the part number, maybe this will help a bit: #240369702
It seems like this fridge runs all the time with the exception of maybe 10mins in a hour(during defrost?) I have checked the condenser fan running fine, just fyi. I have not performed any of the defrost test yet, as I will wait the full 24hours... and will attempt to check the defrost components tommorrow. I have taken some pictures of the evap coils, please have a look and provide some feedback... it would be greatly appreicated.
Jason
evap pic 1 picture by cdnhawk02 - Photobucket
IMG_1399.jpg picture by cdnhawk02 - Photobucket
Evap 2 picture by cdnhawk02 - Photobucket
IMG_1397.jpg picture by cdnhawk02 - Photobucket
#6 Posted : Monday, September 14, 2009 5:30:16 PM(UTC)
Many units do not have a powered damper. Sometimes it is just a knob with a fin or fins on it and they close off/open up the air channel from the freezer to the fresh food section.
Also check that the condenser coils are clean
Is this what the coils looked like when you first opened it up or has some of the frost/ice melted off the upper coils?
If it looked like this when first opened up, then frost on only one section of the evaporator coils (especially if it is where the freon enters the coils from the compressor) is a symptom of low freon.
Where it is iced up it does look rather heavy.
Low freon or dirty condenser coils will cause the compressor to run more.
You may also want to check the door seals. Take a dollar bill and close the door on it at different spots around the perimeter, if it pulls out very easily then your seal is no good. This will also cause excessive run times and excessive frosting up of the evaporator coils. Also check that the gasket on the hinge side is not folding over as the door closes.
I hope it is not low freon as often it makes more sense to buy a new unit than pay a pro to find the leak, fix it and refill the freon.
PS I was able to find the fan at AppliancePartsPros but it is used in a multitude of different units so did not help in getting specific info on your unit.
cdnhawk02
#7 Posted : Tuesday, September 15, 2009 2:49:43 AM(UTC)
cdnhawk02
Hello again. Please see comments in RED and FYI for additional details.
-Condenser coils were already cleaned... previously. :(
-Yes this is what it looked like, maybe 30-1 mins after I opened the evap cover. Does that mean I am SOL and should give up with the DIY method??
- Will check the door seals if you think it's worth it at this point?
FYI : I was able to find my fridge on your site with another model number; it's the exact same fridge. See how in the Cabinet diagram there is no dampner flap.. just a shoot that lead into the fresh food section?
Model number: GLRT13TEW3
#8 Posted : Tuesday, September 15, 2009 4:17:06 AM(UTC)
No I would continue with your trouble shooting.
Check out the defrost to make sure it works.
When the coils are completely free of ice/frost, button it up temporarily, let it run for an hour or so then again check the evaporator coils for a fairly even coating of frost.
Here is the fan
Part number: 240369702
NBLANKE
#9 Posted : Tuesday, September 15, 2009 5:19:19 AM(UTC)
NBLANKE
Just had this exact problem: The fan-motor was dead and hole from freezer to fridge was ice-blocked.
Fan motor was located under pop-off plastic control-housing inside fridge, on "ceiling" of fridge. Removed housing, replaced motor --very simple!-- cleared ice from hole which allows air into fridge from freezer-compartment.
New elec motor was very cheap--under $20, I believe.
That solved our problem.... Hope it solves yours!
NOTE: It was surprisingly simple and very quick, once we had it figured out. We are not appliance repair people at all, so it took quite a while to eliminate other possibilities.
Try this: Clear hole of any ice. Pop off control-cover... check fan motor--if fan isn't turning, and is hard to turn w/ your finger--it should turn very easily-- the motor is prob dead.
cdnhawk02
#10 Posted : Wednesday, September 16, 2009 3:59:53 PM(UTC)
cdnhawk02
Here is the fan
Update: So I continued to trouble shoot here are the results below:
1) Defrost Timer is working fine, no sizzling after 15-30min.
2) Removed Defrost Heater wire and tested for continuity; had resistance about 045- 065.. not open.
SO does that mean I should be looking at replacing the defrost thermostat then?? I had quite a build up ice like the previous picture when I first opened it up.... Denman do you still think it might be freon?
Another question: About the condenser compressor should it be HOT to the touch? (Keep in mind this thing is running quite a bit)
Also I read that you should be able to touch the High pressure side lines and they should feel cold? Is that correct??? Sorry I have been reading A HELL of a LOT of information over the last couple of days.. LOL
THanks again!!
Jason
GE GBS22HCPAWW - Refrigerator not cooling, but freezer is working (Refrigerator & Freezer Repair)
by drl213 10/16/2009 6:34:42 AM(UTC)
by geri 7/22/2007 3:17:51 PM(UTC)
2 Pages12>
