BestHomes
#1 Posted : Wednesday, January 23, 2008 10:01:36 AM(UTC)
BestHomes
Hello,
Maytag oven model# MGR 4451 BDW doesn't bake.
Top burners and all else works OK.
Igniter looks burnt, and basically fell apart when I tried to unscrew it.
Any ideas besides igniter?
Thank you!
BestHomes
#2 Posted : Wednesday, January 23, 2008 10:19:18 AM(UTC)
BestHomes
Originally Posted by: BestHomes Go to Quoted Post
Hello,
Thank you!
Correction:
I meant the "Short Oven Sensor Kit" fell apart when I unscrewed it.
Any ideas besides replacing it?
Thank you !!!
#3 Posted : Thursday, January 24, 2008 10:11:30 AM(UTC)
The oven temperature sensor has to be replaced first before we can proceed with further diagnosis.
- The part number for the oven temperature sensor is AP204835
BestHomes
#4 Posted : Thursday, January 24, 2008 10:18:37 AM(UTC)
BestHomes
Will do, Gene.
Thanks again !!!!
Nice board and GREAT techs !!!
junkyard38
#5 Posted : Friday, January 25, 2008 5:01:11 PM(UTC)
junkyard38
Amanna Model ARG7600WW P1143333NWW.
Cleaned the unit and all went fine this is the last time the oven worked prior.
Broiler works fine and lites off .Canceled the operation.
Cleaning feature works fine an lites off. Canceled the operation.
Stove top functions fine.
Remedies I have tried per a repair man.
Replaced the electronic module, oven does not function.
Because the unit did not bake at the required temp I needed to add 5-10 degrees to the temp setting, I also replaced the temp probe at the same time.
I cannot find a in line fuse nor any other part that has anything to do with the baking cycle. There are no burnt off wires at the terminals.
This repair advice i received has cost over $200.00 and still no oven to bake in. If anyone out there can shed some light what I need to do it would be appreciated to get this oven functioning.
Thank you ,Don
BestHomes
#6 Posted : Friday, January 25, 2008 5:46:35 PM(UTC)
BestHomes
Junkyard,
You posted your problem as a "reply" to my problem.
You'll get better exposure if you continue posting under your thread (if you already have one started) or click on "POST NEW TOPIC" and post your problem.
Good luck!
