longleggedfirecracker
#1 Posted : Saturday, September 12, 2009 2:00:03 PM(UTC)
New machine delivered about two weeks ago. Have done about 10 loads since then. Put a load in last night (not heavy) and this am, water still in tub. Usually, it is probably an unbalanced load, so I "fluffed" the contents and reclosed the lid. No Power! Have checked circuit breakers, power supply, and trying different cycles with no avail. Also checked drain pump (no kinks and at right height). I did notice that this washer makes some clunking noises when the water is filling, which did not happen with the older washer. The dryer and electricity for that area are fine/work, and checked the washer power supply with a hair dryer- which worked. Maytag is supposed to come out Tues, but would like clean sheets before then...any suggestions?! Thanks! :confused:
sidfink43
#2 Posted : Monday, September 14, 2009 6:40:00 AM(UTC)
sidfink43
You are still under factory warranty, so get a factory tech out and they will fix it for free.
